XTR - Custom Statistics
XTR - Custom Statistics 1.0.0
This add-on allows you to create custom statistics fields on your forums.
This add-on allows you to create custom statistics fields on your forums. You can revise the phrases as you wish through your language file.
I want to make an important reminder.
Yes you can show the areas you want as a widget but I recommend not to use it in the sidebar.
You can simply add a widget if you want to show it in any template
<xf: widget key = "widget_key" />
