Resource icon
Xon - Standard Library 1.22.6
Xon - Standard Library got a new update:
Download Standard Library by Xon 1.22.5 Latest Version.
New Changes:
  • Fix incorrectly using SqlJoinTrait would swallow the actual error
  • Improve detection of excluding non-required joins when using EarlyJoinFinderTrait. This affects Multi Prefix is optimizing for matching on a single prefix, and also Extended Ignore
  • Remove usage of assert() for XF Cloud compatibility
Read the rest of this update entry...
New Changes:
  • Partial workaround for buggy XF2.3 behavior around repository uniqueness. Does not affect call sites to \XF::repository, only Helper::repository
  • Improve detection of excluding non-required joins when using EarlyJoinFinderTrait. This affects Multi Prefix is optimizing for matching on a single prefix, and also...
View Xon - Standard Library 1.22.6 - Bugfix update Latest Version.
New Changes:
  • When using "AJAX pagination with filter bar" (js/sv/lib/xf/filter.js), fix invalid javascript error message when filtering by a value without pagination wrapper
    • Noticeable on the "logo selection" page of the Selectable logo (paid) add-on
