DCom - AdminCP Style
DCom - AdminCP Style 2.2.9
Dark style for AdminCP
[DCom] AdminCP Style
Screenshot 2022-06-02 at 11-12-55 Development for XenForo - Admin control panel.webp
This plugin converts the control panel to a dark style.
  • The plugin has color settings.
  • Also, the design of the template editor (CodeMirror) with a choice of 10 styles has been made a separate setting.
  • All these settings are changed only in the master style, so you need developer mode to change it.
  • Added the ability to customize the login page in the Admin panel.
  • Ability to disable customization of the login page or the panel itself...
