AP - Style Suite
AP - Style Suite [Paid] 2.16.11
AP - Style Suite Xenforo Addon
AP - Style Suite
This addon allows users to customize the appearance of the username, custom title, profile, and postbit, by adding 4 new pages to the Account Details section. It also expands upon Account Details by adding a new drop-down field that allows users to add a frame to their avatar.
As of v1.5.0, the addon also extends [tl] Social Groups, and allows groups owners to theme their groups however they...
AP - Style Suite got a new update:
Download [AP] Style Suite 2.16.0 Latest Version.
New Changes:
Note: Please ensure that the ap_ss_asset_avatar_frame.less template is successfully merged post-upgrade.
  • Add "transform" to list of whitelistable CSS properties
  • Various internal cleanups
  • Remove "Avatar frame type" admin option
  • Add native support for Steam frames
    • "This is a Steam frame" must be checked in the relevant asset settings
    • It is recommended to upload steam frames to a folder via FTP and link to their path in the Asset path...
Read the rest of this update entry...
Download [AP] Style Suite 2.16.4 Latest Version.
New Changes:
This update addresses issues strictly related to installing the addon - if you already have it installed there's no need to upgrade to this version.
  • Correct output of AbstractAsset::getDataDir() in order to fix issue where assets would not be imported during a fresh install
  • Stop creating "ap_ss_avatar_frame" column on User and UserGroup table during a fresh install as its not longer necessary
  • Fix issue where the "usable_users" column would not be set up on the asset table...
Download [AP] - Style Suite 2.16.5 Latest Version.
New Changes:
  • Fix issue when editing an existing asset font, where the uploader/preview text would be hidden
  • Fix issue where postbit preset backgrounds would not apply
  • Fix Call to undefined function XF\Image\imagewebp() when uploading a postbit background with GD
  • Fix issue where solid color would not apply in the live-preview for custom title, post & username styles
  • Fix Call to a member function run() on null
  • Return early in Templater::fnAvatar() if a user's avatar frame style...
Download [AP] Style Suite 2.16.8 Latest Version.
New Changes:
  • Create "View custom blocks" permission so guests that cant change block settings can still view registered members blocks
  • Address reports of an assets stored URL not reflecting the new data directory structure
  • Fix another formatSelectableColors(): Argument #1 ($colors) must be of type string, null given
  • Don't generate a tooltip when hovering over the avatar frame preview
  • Allow "avatar--square" to be applied even if "no-avatar-frame" is set
  • Fix issue...
Download [AP] Style Suite 2.16.10 Latest Version.
New Changes:
  • Various profile preview fixes
  • Enforce a stricter check when updating asset_url during the 2.16.8 upgrade
  • Fix issue where image position, etc, could not update unless the uploaded image was also changed
  • Fix: Cannot access offset of type string on string
