Andrew - Moderator Panel
Andrew - Moderator Panel 2.0.9
A suite of enhanced options and visibility all built into a single moderator panel
[Andrew] Moderator Panel
[Andrew] Moderator Panel provides moderators enhanced visibility into user behavior and additional moderator features. The thought is that by providing better visibility to warnings, reports, thread bans, and ignores, moderators will be able to identify problem users faster and will rely less in impulse when making decisions on users. All features are permission controlled and can be enabled or disabled.
Andrew - Moderator Panel got a new update:
Download Andrew - Moderator Panel 2.0.9 Latest Version.
New Changes:
  • FIXED: IP address was visible on recent login log for users who did not have permission to view IP
  • FIXED: Updated user note "entered on" phrase to make easier to translate
  • ADDED: Confirmation to user note deletion and used POST to delete
  • FXIED: Moved permission check logic to the entity
  • FIXED: Removed country filter if no API was configured
  • FIXED: Removed columns on profile and recent login page if no API is configured
Read the rest of this update entry...
